Anybody running Elites Precision 6466 Kit
dseitler
Royal Palm Beach, FL
any news on installed units?? Maybe you guys can have the tuning dialed before mine arrives, lol
If your going to run Dual Fuel Tuning won't be a issue at all. From the Tunes that I have tested with Tadd and Matt (over 50) there are plenty to choose from. It will all depend on how crazy you want to get. With a Non-VGT Turbo the most important step is the Trans tune first then the engine. If you follow that it will save you and the person who is doing your tuning a lot headaches. FWIW
1bad6.7
I need a tune with this set up, Do you know if they have tuning for this turbo and stock fueling? I have been driving around with my check engine light on... I'm ready for it to be turned off!
BOHICA256
Midland, Texas
You mind making a video of the exhaust/walk around? Curious about how it sounds. And how is it handling the tuning you have now?
dseitler
Yes I know Tadd @ Elite has Tunes for that and his Trans Tune for the Non-VGT is Spot on.
50_shooter
Central IL
It's here, now just need somebody to put it on!
I was surprised, there is a shytload of parts that came with it. Welds look really good in my opinion.
50_shooter
Central IL
Near Effingham Illinois. I thought about Scheid's, since they have a shop in Effingham, but I don't know how much they mess with the newer fords. They do a lot of cummins stuff I think. I am also seriously considering RCD. Im sure they could do it.
I would like to do ALA's, a carli level, and amps at the same time. Oh, and exhaust. I have a delete pipe and egr block offs for the truck, but never deleted it. I have been running dpf on until I got some miles on it, then I bought the kits (Turbo and DF) so I figured I'd wait to delete it until everything was installed at once. Figure I probably better go with a full 4" exhaust now.
Administrator
let me know if I can help you with anything else ya need. scheid could definitely do it well if you decide to go that route. just call and ask for brad Ingram .
50_shooter
Central IL
Is he in Effingham? I think they have a shop in Terre Haute too, which isn't much more than an hour from me as well. I may hit them up if you think they would be good. I just want it done right.
What will I need for tuning it? I have a high sulfur capable mini max. I'm assuming I will need an MCC unlock code for it?
50_shooter
Central IL
Another thing, I am pretty illiterate in turbo speak. I bought the wastegate option. It is a Precision 39mm. I noticed on the box it says 25.7 psi. Surely that doesn't mean it won't allow boost to exceed 25.7 psi does it? I don't understand what that means. If that's the case, that seems awfully low to me.
Administrator
yep hes at the effingham shop , at least he has been forever.
jcain
50_shooter, make the drive to KC and I'll help you put it all on over a weekend. Might as well learn to wrench on your own truck and take pride in knowing you did it right.
jcain
That just means it has a 25.7psi spring and if you didn't run a reference line (boost controller ) to the diaphram from a charge pipe it'd open at that spring rating (that's not always a factual number).
dseitler
Drive to FL. We will put it on, Dyno the truck, you can take it to the track on Friday night and you also can work on your tan.
