Build thread, Triple Turbo 6.7L Race truck build
97stoker350
south central pa
Is that not because the way of making the block makes it stronger than cast? Therefore no need for as much material which cuts down the weight.
Craig@MFI
Our block is 3/4 filled so we cant really tell how strong the stock block is but so far it's good
Athens, IL
Well, you can use a stronger material and use less. And it just equals what's necessary. Or you can use stronger material at the previous rate which equals more strength... They may have a stronger material, just very thin. So overall strength is not known yet.
Craig@MFI
Ending the night with one head on hoping to end our journey for that 9 sec pass this weekend with a few little modifications we have done
B585Ford
WV
Good luck. I would love to see this thing get in the 9s on fuel only.
Craig@MFI
Just leave this here after the new gaskets....
Craig@MFI
1.5 passes on this set of gaskets we tried arps this time not gonna say it is there fault completely yet but we had 100 passes on our h13s and never blew this bad
Jbenso127
Centrallll Florida
Where did the gaskets fail the first time, when the factory bolts were put back in?
100% studded now? That's a bummer.. Held better with the stock bolts thrown in the mix lol. Hate to see it Craig.. Hope you guys give it another shot before putting it away for the season.
Craig@MFI
This time it held worse than the h13s and the 4 top stock bolts I'm not pointing finger yet but I would find it hard to believe the block is cracked
Thats crazy im with shone i would have thought a hose would have burst before that.
hopefully its not the block, personally i wouldnt be surprised that thing made some power for a long ass time
