Isspro EV2 3 gauge package
Powerstrokeracing
Hmm, ive been looking at these. I just need the gauges though. Wish there where 4 also.. Seems to be a good deal these gauges aren't cheap.
not enoughsmoke
lynnville tn
they turned out nicey and i wired the motor at the same time so it turned out cleaner than expected
CSIPSD
Bend, OR
when i opened the box all i found was a ball of wire
6 wires for boost
5wires for pryo
5 wires for trans
Again, you only need one common ground, one common power, one common lighting, all those can run from one gauge to the next using the connectors provided.
Then you have a three wire sender going for the boost gauge, two wires going for the pyro and two for the trans temp.
They are about the easiest gauges on the market to wire, short of the Performax line which have three wires to run up to 17 gauges...
