6.7 EGR Block Off??
Jacob @ No Limit
Indiana
Ok so I have been looking for the block off plates to remove the bellows pipes going to the egr cooler. Can I order an egr delete kit and use the plates that come in it, or what? Do you just block off at the engine or at the egr cooler also to keep junk from getting in it? Thanks in advance!
Mpoage
OKC, OK
This is what you need.
H&S Factory EGT Solution
Jacob @ No Limit
Indiana
The thing is that I don't want to do a full delete right now, I have a full delete kit. I just want to block it off for now. Will my plates from my full delete kit be all I need?
Sterling6.7
You can. I just trimmed up a couple of pieces of sheet metal and used the original bolts with spacers to hold them on. Helps keep the crap out. I have not read where it needs to be done though.
