Help!!!
Bad_company
04 6.0 big fuel leak from driver side after studs. Checked banjo bolts check under pressure regulated and top side of upper filter housing... Seems to be coming from down low. Checked fuel line fitting that run by the head and they are dry... Running down across engine cross member and down the oil pan... Where the F@#& could it be coming from?
Trqmnstr
VT
The fuel pressure spring housing gasket?
Im sure you checked but when mine was leaking it looked like the leak was a lot lower than it was.
Bad_company
If u look through the wheel well u can see it dropping off of a tab from the head gasket it's self
Bad_company
The drive front corner. I've checked everything from the filter housing and regulator down.
