Valve spring compressor
Homesteader
I will be doing my valve springs soon,so Im looking for who makes the best compressor tool .
Homesteader
Ok guys sorry no AutoZone or Ford here just Napa. But if I have to order I will. Anyone have a pic. Is there different styles?
co04cobra
WV
No ? if you can get the Rotunda (Ford) one that is the way to go. I can get the part # off mine if it would help.
Arisley
Arlington, Texas
There was a thread over on the Nation about one a guy made. You could change the springs without having to jack the motor up. It was pretty slick. It was similar to the rotunda tool. I think he was going to make and sell them.
I have the same one that Ron posted in that thread, while it works and will get the job done, you do have to rock the motor over.
V-Ref
9 miles high @ 550 mph
Rotunda PN 303-483
Ford PN T94T-6513-AH
This is the one I've used, haven't used any of the others to compare. It came in the Rotunda 7.3 special tools kit. Worked like a champ compressing the factory springs. Needed to use a longer bolt to compress the WOP/Crower springs, as they're a bit taller than the factory ones.
Homesteader
Rotunda PN 303-483
I was thinking of making a tool similar to that. Also I think those are the same springs I'm going with (WOP). V-ref how did that tool cost you?
Homesteader
Is that kit worth it with those tools missing? Im thinking of building a tool.... Hopefully
