7.3 short block, OBS turbos, misc powerstroke parts to sell ASAP!!!
Strokersace
Towanda, KS
NEED TO SELL!!! Have way too much stuff sitting collecting dust.
3 OBS turbos - Over 250K on each and will likely need rebuilt: $100 OBO Each
2 OBS Pedestals - good condition: $25 each
Complete set of Stock push rods. Great shape and none bent. $50 for set
Complete set of stock valves (intake and exhaust) plus rocker arms. Great shape: $50
Core short block motor:
95 Powerstroke w/ 168K when pulled. Bad compression in the #3 and #5 cylinders I believe. Was using oil. Block with internals and NO heads. No injectors, wiring harness, turbo, fuel bowl, or high pressure oil pump. Pulled from an old pickup of mine and have kept it to rebuild someday. Just need to get rid of it.
$100
Oil Pan: Good shape. Removed from a 95 Powerstroke. $25
Various exhaust up-pipes, collectors for the back of the turbo, manifolds for OBS psd: $$Make offer$$
3 OBS Engine covers: $15 each
OBS Air Filter intake stock: $25
96 set of heads:
approx. 160K miles. They are stripped, ready to be cleaned, ported/polished, and rebuilt. I bought them used and never did anything with them. The block surfaces look fine. $100
00 set of heads:
approx. 175K miles. Complete except for plenums. Great shape. Rebuild if you want to or run them. $150
E99 Intake Spider:
Tapped for boost gauge on hot side. Has all boots etc. Perfect for OBS guy putting an I/C on. $150
6.0 I/C:
End tanks fine as is the cooling area. The top mounting "forks" are broke, but the tank is not cracked or compromised. I was just gonna smooth it out where the tabs are broke and make my own upper mounts to bolt onto it. Would be perfect for an OBS guy that is custom mounting one. $100
It's OBO on everything!!!
Can possibly deliver in Montana, northern Idaho, or eastern Washington.
Wet siders in OR or WA, if you want anything, I could work out some way to get them out there via other members.
PM or call me at 208-316-1828
Strokersace
Towanda, KS
Chit Patrick!!! Still haven't had a chance to dig thru the totes of parts in the storage unit. I hate living out of boxes and storage units!!!
I'll find out how many good ones I have and pm you.
bump on the rest. I just wanna get rid of the crap.
Strokersace
Towanda, KS
1 Turbo and pedestal SOLD!!
Leaves 2 turbos and 1 pedestal left... Plus all the other stuff from the 1st post.
Strokersace
Towanda, KS
Update...
1 OBS Pedestal - $25 each
$100
96 set of heads:
00 set of heads:
6.0 I/C:
End tanks fine as is the cooling area. The top mounting "forks" are broke, but the tank is not cracked or compromised. I was just gonna smooth it out where the tabs are broke and make my own upper mounts to bolt onto it. Would be perfect for an OBS guy that is custom mounting one. $75
Strokersace
Towanda, KS
UPDATED LIST - want to sell everything!!
3 sets Stock push rods. Great shape and none bent. $30 each
2 complete sets of rocker arms and bolts: $30 each
2 complete sets for injectors hold down bolts: $15 each
6.0 I/C:
1 OBS 100V IDM: $100
1 OBS alternator - reman near brand new. Was still charging good when pulled: $50
SD psd Fan clutch - was working great when the truck was parted out: $85
SD psd Motor mounts - great shape: $50
1 OBS 1.15 A/R stock exhaust housing: $50
2 OBS Turbo Exhaust Back pressure valves - still have butterfly in them: 25 Each
Strokersace
Towanda, KS
UPDATE
3 sets Stock push rods. Great shape and none bent. $30 each 1 sold - 2 left
2 complete sets of rocker arms and bolts: $30 each 1 sold, still have 1 set
2 complete sets for injectors hold down bolts: $15 each 1 sold, 1 set left
3 OBS Engine covers: $15 each MAKE OFFER
6.0 I/C:SOLD
SD psd Fan clutch - SOLD
2 OBS Turbo Exhaust Back pressure valves - still have butterfly in them: $25 Each
Strokersace
Towanda, KS
6.0 I/C:SOLD
1 OBS 100V IDM: SOLD
Bump.
