Drive pressure gauge
Six_Sloww
Southeast MI
Probably going to be spraying my truck this summer so I figured to be safe I should probably put a drive pressure gauge on it.
Anyone just run a T off of the factory ebp tube? How did you do it?
i would drill and tap another port in the manifold and run a mechanical boost gauge.
Six_Sloww
Southeast MI
I could do that, but why not use what's already there? Not to mention it's cooler by the time you get up to the ebp sensor and I could use less copper tubing.
i dont know about 6.0's but 6.4's are extremely finicky with the epb reading and causing a check engine light. i would be worried about affecting the stock sensor reading but i may be over thinking it.
Six_Sloww
Southeast MI
Well with your current setup I would say your not using the EBP sensor so I would just take it out and put your drive pressure gauge in place of it instead of doing a "T".
I think the pcm uses the ebp for more than just VGT related calculations.
Six_Sloww
Southeast MI
Lol anytime I ask eric if I can throw something out he shoots me down.. I still have my damn egr plugged in lol!
Six_Sloww
Southeast MI
LOL LOL I have never had a EGR plugged in but I did ditch the EBP sensor on one truck no difference at all in the way it ran used that for EBP sensor.
I'm sure he's just covering his ass because of multiple strategies and differences through the years.
KCTurbos
I run an electronic back pressure gauge. You don't want a mechanical gauge because it will soot up and stick.
Lol... I have a mechanical gauge and I have to clean it out about every 6 months. I am sure it's is going to fail eventually because of all the soot.
I just tapped another spot in my exhaust manifold next to my pyro
JDub
Hooper, Utah
I've been running one in my Duramax for almost two years now and never a problem. I drilled and tapped another hole in my manifold, and ran some coiled tubing to an Universal 0-100 Edge EAS sensor. Watch drive pressure on my CTS just like everything else. Sure nice for datalogging...
