webb06 official build thread
webb06
Seneca, MO
A few mock up pics to see how everything is going to fit
webb06
Seneca, MO
Fuel block may end up getting moved somewhere over on the valve cover to make room for an intake of some sort. Not much room for it to go to the passenger side so I think it'll be towards the drivers side.
webb06
Seneca, MO
Looking good Dylan. What is the estimated hp your gonna be pushing? Any idea
Corsilli did 910 on fuel with basically the same thing so somewhere around there. Over 1000 on nos id hope. Hopefully running high 10's in the quarter is the main goal.
webb06
Seneca, MO
Converter showed up a yesterday after getting sent to precision to be restalled. 2200 stall and steel stator now.
Quick question for anyone who may know. The converter came with a spring to replace a spring in the pump. I remember when I first got the converter it came with a spring too and I don't think it ever got put in. Do I need it now?
powerstroked08
Pennsylvania
Would be my guess. These remans are a crap shoot anymore. Not worth blowing a perfectly good motor over a sh!tty pump dumping fuel into the crank case.
Tree Trimmer
i'll wager it gives you more room elsewhere for turbo's etc etc.
it's probably not so much about advantages/disadvantages, but more about how to pack in everything under the hood that you want packed in, and relocating things is whats needed.
webb06
Seneca, MO
not much has happened with this project lately. dropped the cab on it and shoved it in the corner because we needed the lift to work on a customers truck.
had someone local interested in the built engine but I guess he's no longer interested. hopefully i can have it running by the end of the month if all goes smoothly.
I sold the airdog and bowl delete. going to use an a1000 pump. where can i get the filter heads for the fuel filters?
Tree Trimmer
if your just going with a spin on fuel filter, we always use baldwin filter bases. really any parts store.
