high idle when driving
mattl140
canada
80% of the time my truck idles high say 850-900 rpm when in drive and when i put it in neutral it idles back down any ideas? 99 f 250 thanks.
Atsah
Maine
Isn't there a switch or something in the brake pedal that cut's the high idle out? Any truck I ever had the brake pedal would disengage the high idle.. When the truck is sitting and you touch the brake, does is bring the idle back to normal?
ghohouston
Lewisville,Texas
Yes, the brake pedal kicks it out of high idle. At least on all the big trucks, 6.7 cummins in the dodge pickups, 7.3's and 6.0's. Can't comment on newer powerstrokes.
mattl140
canada
yes when i touch the brake it kicks off high idle. but in drive 80% of the time it idles high, when stopped at a light its idling high i put it in neutral and it idles back down then it will happen again
Atsah
Maine
What temps are we talking? IDK if it's the same but I have noticed my Taurus doing the same exact thing for the past two weeks (5F-10F for a high)..
mattl140
canada
its done it at 0 and its done it at -20 it gets really cold here and I've never seen it do this in the past winters.
Atsah
Maine
I see.. Hopefully someone will have some input that knows how the system works..
mattl140
canada
my icp is bad i will change it and see if that helps, I've known for a while its just the dealer wants 250 bucks for the sensor.....
mattl140
canada
ok so i changed my icp and the connector and it stopped the high idle when driving but it seems like it idles abit better unplugged any ideas thanks.
