Issue with DEF warning on dash
UNBROKEN
So I showed the 500 miles to empty warning for DEF. Since I'll be deleting next week I only put in one 2.5 gallon jug of DEF....less to drain out later.
Now the warning is still on the dash every time I start the truck and it's counted down to about 360 miles left now. I scrolled through all the menus on the dash and can't find a way to reset it. Did I miss something or do I have to fill it all the way? I really don't need it going into limp mode before I can delete everything. LOL
jwalk09
VA
I haven't refilled mine yet, but I've read where you almost have to fill it up before it resets the gauge
04stroker
Sarasota-Bradenton, Florida
You have to basically fill it up for it to reset do not think there is a manual way to do it. There is not a float sensor in that tank just 3 or 4 (cant remember exact amount) of level indicators down the side of the tank and when it hits each one and gives you the miles based on calculations it makes between those sensors and and how you drive.
UNBROKEN
Great...guess I'll have to pump 5 gallons of that crap out next week.
Thanks
POWER-STRUCK
Indiana
Has 2 anode rods. Can determine full half tank or empty. The rest it just averages. So if you get to half tank the light will go off
12stroker
Corpus Christi, TX
just use water to top it off.. unless they changex something in the 15s, i ran 16k miles runnijg water from the garden hose before i deleted it..
bingo... i did the same when i returned my truck to stock to get some work done. deluded def to get rid of the crystallization in the tank and lines.
67boost
So is running water in an active DEF system safe?
That's what I understand, but I just want to be sure.
It's fine. It's just not going to do its job. I would imagine if you did it enough and it was pure water in the tank you would get a code for it.
i ran 15k on nothing but hose water then got a low quality def code.. dumped a gallon of def in it and code went away. started using water again then i deleted the dpf..
UNBROKEN
All that sh!t fell off the truck....haven't had a single issue since. :)
