It's nice to see that all the reman items from the fuel system are of such good quality
Just so everyone knows I ran these injectors for about 2000 miles and never had a single code or issue from the truck. The only reason I pulled them was I had to pull the turbos to fix a hpfp leak from me reusing the factory return line and figured why not. It kinda make you wonder how many people could be running around on bad injectors. I don't know what running injectors the are returning to much fuel will do but that is why RCD said they failed the flow bench.
do they have a spec sheet you can post? at what pressures were they tested to?
