DHDP Build
powerstroked08
Pennsylvania
I agree with Morgan, i don't see any need for main studs in a bed plate engine. Just take that money and buy something else that will make power!:ford:
Poglife
Georgia
what size an fitting and hose do you guys use for fuel cooler delete -8?
and should I just remove the front cooler as well? is there any use for it or can it be repurposed
Csilva187
I used 3/8 hose with Parker fittings. Also, I douched out and reused the old coolant exchanger as a fuel cooler exchanger now. Pull the driver side fender well and make your 3/8 to 1/2"ish jump there to tie in, if you reuse that exchanger. If ya want PM me I can hook ya up with photos etc?
