WTB rebuild kit for a s475
NRHX2009
Elizabethville, PA
As far as i know there is not a T6 1.0 A/R housing. There is a T6 1.10 A/R housing for the 96x88 wheel.
Wheel sizes as follows:
96x88
87x80
83x75
Should be one of those. Can you measure the turbine wheel, that would be a better way to tell. Turbine wheel size effects the piston ring size on turbine side.
stackedstroker
summerfield N.C
I bought it from. Guy on powerstroke nation that bought it from another Guy on powerstroke nation, when I asked the original owner of it he said it was a s475/83 with a t6 flange I'm assuming that means its a 75mm compressor and a 83mm turbine .
I can measure it later if I need to? Do I just measure the outside of the turbine wheel?
NRHX2009
Elizabethville, PA
Yes, take the turbine housing off and measure the smallest part of the wheel straight across from eachother. That is what i recommend to do.
