dsberman94
Pennsylvania
Started tearing apart the interior around 10:30-11 this morning. Looked like an explosion went off by the time I saw 1pm. Everything straight down to paint except the dash, glass, and A and B pillars was on the garage floor. Sound deadened the back wall, rear pillars, and the entire floor with a double layer around the front where the front seat foot space is.
didn't even get half
Way done with the back seat floor before the roller tool broke, so I just used it without the roller. Still seemed to work pretty well until the very end when the coating seemed to start rubbing off eventually. By 1:30 am carpet, front seats and console, and all plastics were back together. Just going to get a quick vacuum out tomorrow then reinstall the amp, sub, and miscellaneous center console junk. Looks like a spaceship inside under all the carpet. And not a bit of the deadener is able to be seen from above. Never know until you pull the carpet up.
01pwrstkr
Polk County NC
Looks good!
"3 can keep a secret if 2 are dead"
You also bought the thick membrane correct? That stuff you're rolling down kills vobrations, but that's pretty much it. To really make it quite there's two other products you put down after the dynamat.
GatorBaitR6
Gray, TN
Looked her thought about working on her then remembered its cold and I need to install my new exhaust and faring kit on my R6. Speaking of which anyone wanna buy and R6 lol.
01pwrstkr
Polk County NC
Finally got my led fog light brackets in and was able to get my lights installed!
Thanks to JrStroker for the help!
