1000 RWHP Build for the summer
ingrahams
New Hampshire/Africa
Go on leave next week so the truck will be getting the PMF short arm 4 link kit put on, trutrac installed and a nitrous express stacker 3 installed. it will be going to the dyno for some 4 digit power numbers hopefully, after that it will be going to the track for some high 10's (with any luck) then back in the storage unit for 7 weeks. will update when I get back in the states.
-Stew
RSK
Connecticut
-Stew
If the nitrous kit works you will be going high 10's as long as the trans shifts perfectly, 1050hp should put your truck into the high 10's unless its heavy even so i'm sure the nitrous will add over 100hp
ingrahams
no idea, im 340lbs so im not going to go too nuts ripping stuff off the truck, spare and hitch are already off so probably just the tail gate and give her hell. it will get into the 10's one way or the other and hopefully drive home.
-Stew
pog
psa
first and second run have weird torque numbers. but congrats on breaking 1k!
