Stock SD intake spyder and AFE hot side connector
Magnum PD
VA
I Used the AFE cold side on my setup so the hot side that fits the stock SD turbo was unused.
Got a used SD fuel pump. $75
Rebuilt SD turbo. $150
First gen wicked wheel
Magnum PD
VA
No turbo. This is just the hot 90degree turbo discharge pipe.
A pic of the kit. But again Im using the Y pipe.
Magnum PD
VA
Ok. I have the stock SD spyder. You could cut off the hot side of the stock one and use the AFE. I'll give you both for the same price.
