468 FMW Exhaust Housing Combos
PABowhunter
Wanted to hear some feedback on what exhaust housing guys with the 468 fmw are running. I currently have the 1.10 with my 250/100s. Truck runs strong, but I always find myself wondering what the 1.0 or .90 housing would be like. When just driving around town like normal, I wish the spool up would come a little sooner in the rpms. This is with an auto trans.
JGman141
Ohio
.90 would give you the quicker spool but your backpressure would be higher, I'd go with the 1.0 so you can keep you backpressure in check.
DocBar
Akron, Ohio
In for the info
Dude, you're avatar is freaking killing me!!! Talk about tons of fun!!! NOT!!!
V-Ref
9 miles high @ 550 mph
What injectors were you running with that setup?
Unlimited Diesel 400cc/200% Hybrids
Which boost gauge was backpressure? Top one?
Yepper, top one drive pressure, bottom manifold boost.
That's with a manual right?
Yep, ZF-6 with 35", 3.73.
How do you like you're new turbo setup
I think the S467.7 FMW 178855 is the best all around single for the $$$ you can buy for the 7.3. The GTX4294R hits a bit harder on top, but spools about the same as the S467.7 w/ 1.10 AR exhaust housing. Cruising EGTs unloaded/loaded are nearly identical. I'd use the $$$ difference between a $1350 S467.7 FMW and a GTX42 for rods and still have cash left over towards a nitrous kit.
PABowhunter
Seeing videos like that makes me want to try 200% nozzles.
May just have to go with a 1.0 housing to help with around town manners. It's a blast on the highway, but wish it spooled a little lower around town.
DocBar
Akron, Ohio
I've been considering this over compounds fro a while. It's one of the reasons I never pushed Pius harder than I did to get the atmo turbo.
How would you compare this turbo set up to a compound set up?
V-Ref
Nothing really compares to compounds does it :)
I think Jdub had it right on his truck once upon a time....responsive quick spooling 500+ hp 200% nozzle gqssb truck...with one of these as the atmospheric turbo when he wanted to dial it up.
