2006 compound build
stroker57
frostburg,MD
2006 xlt ecsb 36,000 miles truck is like new. This compound set-up is capable of 1200+ rwhp It is the same set-up that jesse Warren just made 1200+ on. If the truck sells I will put whatever size injectors in it the buyer would like if someone wants a smaller set to street drive. Now on to the good stuff
Engine
Rcd rods
rcd push rods and valve springs
fresh head
h11 studs
Bd manifolds
custom intake runners
dual hpop
electric water pump
belt driven lpop
air to water intercooler
Two stage nitous kit
Batteries relocated in bed
custom aluminum radiator
Trans
bts 4r100 with pcs controller
Turbos
s468
s483.5
Built by barder
Wheels and tires
Fuel dune 20x12
Nitto 420s
Custom set of traction bars
rear block removed
cowl induction hood
single stack
roll pan
This set-up has zero miles on it just getting finish up and ready to run I would like to get $35,000 for it there's way more invested than that
