ToMang07
Mainah!
lh manifild list $276.03 sell $198.74
rh manifold list $281.35 sell $202.57
dip stick tube list $57.34 sell $34.40
oring list $5.71 sell $4.45
oil pan bolts list $4.46 sell $2.68 each
what studs are you looking for?
q#364604
The ones for the exhaust manifolds.
rman
SoCal
price quote on heads for '03 6.0
after seeing prices on the '15 heads, wondering if it's more cost effective than machining
Sent from my Nokia 5160 using Snake
sunrisefordparts
heads list $1551.78 each sell $1117.28 each w/exchange (core $250 each)
shipping $50
q#364810
ToMang07
Mainah!
q#364604
Ok, I'm ready to order:
Exhaust Manifold Bolt Sets (Enough for both sides)
Left and Right Exhaust Manifolds
Left and Right Exhaust Manifold Gaskets
Dip Stick Tube
Complete set of Oil Pan Bolts
Complete Set of Valve Cover Bolts (Both Sides)
Windshield Washer Fluid Reservoir Cap
sunrisefordparts
Dip Stick Tube
on the valve cover bolts looks like they used 8 bolt and 2 studs per side but the studs are no longer available. i can get you all bolts if that would work out for you .
Pstrke96
Dunnellon fl 34433
Looking for passenger side front hub assembly 2002 7.3 auto 4x4 manual hubs switch on the dash. Upper and lower ball joints both sides and whether or nat they are serviceable
sunrisefordparts
hub list $315.25 sell $226.98
lower b/j list $97.57 each sell $70.25 each
upper list $68.32 each sell $49.19 each
free shipping
q#365812
