Lifted 6.7's
Mikeyfitz
Houston, TX
What system. I'm thinking of doing coilovers. I have a 8 inch rough country and it rides, well like a 8 inch rough country.
Swapped to a true 8" coil from BDS. Then the Fox 2.0 Reservoirs helped so much.
UNBROKEN
How solid does the resi feel with one bracket?
I was thinking about doubling up on them.
Mikeyfitz
Houston, TX
Think the majority of that is the Shocks or a combination of the springs as well? Im thinking of upgrading my 4.5" at some point
Majority is definitely the shocks. But we noticed my driver side spring was a bit more squished and caused a little lean, so we swapped it out for true 8" instead of stacking the level.
drservo
4.5 Icon 1350 Fuel With 37 Toyos
drservo
I Had a shop install the lift, shouldn't the coil be straight and inline with the axle instead of leaning??
Houma, LA
2015 Platinum with 7" PMF Alpha lift, 37x13.5x20 Toyo MT...Shop did not install rear traction bars due to a tight fit with Titan 50gal tank...Plan on getting them on when I get in from offshore.
Mikeyfitz
Houston, TX
Am I gonna have issues on 8" with 22x14s and 37s?
I dont have any with my 12 wides, but curious if 14 wide will rub
drservo
FYI 4 1/2" ICON no where near clears 1350 37 Toyos, major grinding on the front bumper supports.
