CMCx2012
Oh boy... I'm gonna be stuck with this half-assed OEM stereo for the rest of my life.
Thank you so much! Advice taken, and I will surely PM you once the order is in for last minute talk.
I am actively scouting reputable installers in the Long Island area that are both reliable and experienced to deal with said install.
Thank you for the continued posts and advice, guys.
I chose SuperCrewSound to build the sub box based around the plans to install a shallow 10" subwoofer. The box has been on standby with the owner of the company because I was not sure what subwoofer that I was choosing. Some of the concepts for this build are obviously a sealed box, and poly fill or whatever the little stuffing material is called, and these are recommendations on behalf of the builder.
I need to pull the trigger on all of the components, asap, but as of now the front door speakers are looking like Focal FLAX units, but then again those ARC's look like they fit the bill as well.
BLOWN is certainly right- this is hard when you are choosing a total stereo upgrade based on review boards and online reviews![]()
Gonna run through this real quick so if I miss something just ask.
I'm not saying go buy the Arc Black kit....I'm saying Arc rebrands SB Acoustics drivers in their kits. Arc sells the kit for ~$800 bucks. The individual drivers from Madisound are about $75 each. It's a no brainer IF you were doing an active system which I assume you're not.
The Focal Flax is hands down better than the Hertz kit at virtually the same price....that would be my pick.
The Illusion Carbon C10 will beat the JL TW3 in every aspect....but at 3 times the cost. The JL will do...just don't expect to be blown away by it. This is a case of you get what you pay for.
The single most important part will be your install. No matter how much you spend on front speakers if you don't address the deficiencies in the front doors you'll be wasting your money. You absolutely have to dampen the doors but I'm sure you know that already. The next thing you absolutely have to do is fabricate some covers for the big holes in the doors. I use .050 aluminum sheet cut to size, deadened then screwed on. Your door speakers are in a quasi-infinite baffle configuration. If you leave big holes in the door you have a free-air configuration....and a big waste of money. In other words....seal the doors. LOL
Oh yea...while you're deadening the doors, slap some CLD inside the door panels too.
I know many will say use CCF and MLV also and there's pro's and con's to that. The fact is you're never gonna completely deaden one of these trucks. I've tried. I've spent thousands of dollars on dampening and noise suppression and it still sounded like a truck at highway speeds. Yes it was quieter but not dead quiet. You just can't fight that vertical windshield for wind noise. At most I'd add some 1/8" CCF to the inner door frame and call it done. Any more questions fire away...
Is rockford fosgate any good?
Final quandary= I still don't know what amp to select (JL 900/5; HERTZ HDP; etc.) but I will narrow that down soon enough...
I guess I missed it but my assumption is you're only running a front component set and a single sub?
If that's the case I'd be looking for a solid 4 channel amp. Run each front side off 2 channels and bridge the other 2 for some solid power for the sub.
I don't see a need for a 5 channel amp in your case unless you're adding something in the rear.
I figured the crew door speakers out back didn't really matter much between the upgraded fronts and sub, but correct me if I am in fact wrong...
