64F100 with a 6.0
Sprman
Houston, TEXAS
looks like crap Dorian..... don't worry though. I'll be by with my trailer to pick it up and will give it a good home!!! LOLLOL Need to get over to the shop and see it now it's back! prob swing by Friday
Lone Star Throwdown
The BattleToad!!!!!
Sniper32
Stafford, VA
I tried hitting yall up for some tech info on facebook. I wanting to drop a 6.0 in a 55, but dont want to use the oem cluster from the 6.0. What guages did yall use? Can i get everything working w/o the oem cluster?
SEABEE08FX4
Montgomery TX
The OEM cluster in your 55 is going to be mostly mechanical, where the 6.0 will be all electrical. So not compatible there. I would stick to the 6.0 cluster, remove the bezel and have a new one made that fits the dash opening and around the 6.0 cluster.
Sniper32
Stafford, VA
SEABEE08FX4
"The OEM cluster in your 55 is going to be mostly mechanical, where the 6.0 will be all electrical. So not compatible there. I would stick to the 6.0 cluster, remove the bezel and have a new one made that fits the dash opening and around the 6.0 cluster."
I plan on using a dakota digital unit that is all electrical and has a remote "brain" that has inputs for all the different sensors...
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=818/category_id=436/mode=prod/prd818.htm
...I just need to make sure itll the 6.0 will be be able to work w'o the oem cluster.
Sorry for the hijack OP...
SEABEE08FX4
Montgomery TX
SEABEE08FX4
Gotcha, misunderstood your post.
Houston, TX
This is what I gotta do to change tires out.. Lol got my billet axle shafts going in, installing Trans cooler, finishing nitrous kit, and fixing an axle seal. And maybe a killer burn out later today!
Strokersace
Towanda, KS
It's been forever since this thread was updated!!
How's the old Toad doing? Any changes along the way?
Curious on the front suspension after its been on the road a bit. Do you have any detailed pictures and info on it. Shock location, frame notches for bags, what bags, frame width, hub to hub width, etc?
Also what's ride height to drive? How much overall height adjustment with the bags?
I'm going to be building a 1951 F3 dually "shop truck" on air. Want to tuck the front wheels and doing a Chevy a-arm swap. But mine is going to be setup to use as a hauler too.
