2 questions dip stick adapter and camshaft
bfife
on the road
In the process of rebuilding my engine. as I assemble a pile o'parts I am committed to NO leaking dripping oil pan.
Is there a better alternative to the stock dipstick/oil pan adapter. I know Driven has a beautiful billet piece but really, $300? not that its not worth it, but its there something less costly?
2nd question
what is the real world experience with aftermarket cams? are they worth the $$ for a less than 600 hp motor?
granted this is for a 550 tow rig. with 4:88 gears it spends alot of time between 2400 and 3000RPM.
thanks
ToMang07
Mainah!
As far as dipstick, I just used the RTV from the oil pan, let it set up for 20 minutes, and screwed it on. Re-torqued it after it had a day to cure. No leaks so far. *knocks on wood.*
David N
Eastern NC
X2 on this. I use the grey RTV, liberally, over the factory orings and put it together just like you would before.
Arisley
Arlington, Texas
Take it to a shop and wave them weld it in place. Fill the oil pan with water above the dipstick. If water wont leak out, neither will oil.
psduser1
on the road
Some of the adaptors are anodized aluminum, stock anyway. Doesn't weld worth a dam to steel, lol.
Arisley
Arlington, Texas
Not if the adapter is aluminum and the pan is steel. Won't weld worth a crap. I would probably get a steel fitting from Home Depot and weld something on there.
Although, one of those kits would probably do a good job with the grey death added to it.
psduser1
on the road
:D:pint:
David N
Eastern NC
Im pretty sure you can just tig weld er on there...done and done
Its funny you said that. I was going to do just that. Took it to our machine guy that does our farm work and he said it was a no go.
So RTV it was. LOL
Hmmmm? I guess Ill have to ask the five people I know who have done it, how they did it.
neverkickn
AR
Just use oil pan rtv on it. no sense in spending money on an easy cheap fix. Some of these. Adapters are made for people that don't have the luxury of having the oil pan removed from the block. Just clean everything with brake cleaner, apply rtv to the flange and back of the nut, torque it all the way down immediately and smooth out the excess.
Btw, I have about 40k on my 7.3 truck with the dipstick flange done like this
My buddy that owns a weld shop, just called him. You sure can. Theres a process for mig and tig. He was the one that welded another local guys pan and dipstick when we built the 7.3 for his mudtruck. He did say its not applicable to weld something steel like a spring hanger to an al frame but to seal something, all day.
psduser1
on the road
Huh.
Pm me some details, I'm always interested in a different process.
