7.3 code reading
Arisley
Arlington, Texas
Neither one, really. More OBDII than OBDI. A cheap scanner will do you no good. Parts store scanners are no help. You need a good scanner. Diesels were not required to adhere to the OBD rules back than.
AE or above for a real scanner, I have heard of some apps that will work.
Justin@DP-Tuner
or 70k like my dually... lol.. oring issues started it all... prolly still be stock if they didnt give up...
Lol, if only you would've spent the 100 bucks in orings and install the stock injectors back....
i was a newb at the time.. ford did that... 15k later, failed again. said f-it and got what i have now.
