Manual transmission swap
I can get my hands on a 5S-42 trans and all parts needed for the swap with the exception of drive shafts for $1000. I want to do a swap because I will be making more power soon, I doubt my e4od has much life left at 60000 miles since the last rebuild and I love shifting. My truck has 4.10 gears and is on 35s, how is the 5S-42 for my setup(looking for first hand knowledge)? Also will I have problems when it comes to figuring out what clutch to use since the part numbers are different for a 5S-42 and a 5S-47?
blackcloudpsd03
My neighbor has stg2 injectors and sbc single clutch with barders diy 63mm 5 spd boy oh boy does that thing pull good..
I too am interested in a manual swap I have 4:10's also
7.3psd97444
Indiana
I have 4.10's, and a 5 speed. Mods in my sig. I honestly don't like it. Can't wait to do an auto swap. 5 speeds are sloooowww.
Bugman
Gypsum, Co
Same here, it's god awful, and damn near red lined going 80 on the highway.
An automatic isn't going to help that much, you need to do a gear swap.
I'll run my truck at 80 all day long with no problems with the 5 speed and 4:10's
blackcloudpsd03
Shift faster... Lol my brothers dodge is fast.. Then again a nv5600 shifts smoother with shorter gears then a zf.
96stacked&smoken
pekin ,indiana
Yeah I would love to swap an auto into mine. The only reason to have a 5 speed is if you like shifting. Otherwise go built auto and do everything better.
old man dave
Petaluma, CA
My buddy did the auto to 5 speed swap. He loved stick cars. 1.5mpg better towing same small 5'ver over 400 mile route. Better downhill coasting control with stick. All wiring worked.
6 months later, he swapped the auto back in, constantly shifting a truck was not as much fun as shifting his 6-speed 392 475hp Challenger. Left leg/rt. arm got tired.:(
Diesel_Brad
Gilbert PA
The problem with the S42 is the Horrific 1st and reverse gears. WAY to high if you actually USE the truck. The S47 has a much lower 1st and reverse. Perfect for maneuvering a trailer.
I dont drag race my truck, i use it as it was intended so the 5 speed is perfect for me. I can be 1000 miles away from home grossing out at 23k and have ZERO fear of my trans leaving me stranded
Rico
San Diego
I have 4.10's with 35's and the 5 speed. Seems as if the motor's rpm's are too high at 80 mph. I've watched semi trucks pass me too often on the freeway
Baker42
New Mexico
I too have a 95 7.3. Swapped in a ZF5s47 to replace the ZF5s42 because of age and syncros. It lags a little taking off in 2nd but once in 3rd she flys. It does rev high (2700 rpm @ 85mph) but it likes it there. The reverse sucks tho with a trailer. I leave the hubs unlocked and put it in 4low (ie 2low), and it's just about perfect. If semi trucks are lapping you, there is something wrong with your motor.
Douganhunter14
I have 410s but at 75 on the highway I run 2500 rpm. It sucks through fuel. Auto trans 4x4 155k never had trans work
Rico
San Diego
Well I'm getting passed because I really can't get to 80 mph. RPM's are too high. 2700 to 2800. Not normal?
