How many miles on your 6.4?
7.3powerstroke00
Brownwood
Well I have over 21k on the engine now and it's still running strong, have had a couple exhaust leaks but other then that it's doin great...
Really wish I could do a single turbo setup but I'm still healing from the rebuild LOL
SlowSmoke
Sylvan Lake, AB
Bought Mine blown up at 254k kms, rebuilt engine and trans. I have put 7k on it since and is running great. It was ******d when I bought it, and obviously still is.
Coated Pistons
Stage 2 Cam
Studs
71/59 turbos
RCD converter
Built Trans w/shafts
Expecting it to last me a long time yet.
I'm glad but surprised to see so many high mileage 6.4s out there. Maybe Canada is hard on them, but very few up here live over 200k miles without cracking a piston.
jimdawg185
I am a few away from that 200k mark as well.
harley2
Alberta, Canada
102k now, at 37k did edge tuner with *** ******, at 60k needed new rad, switched to mini maxx, added Flopro egr ****** with elbow and afe stage 2si intake. at 75k installed BD transmission and torque convertor. at 100k took it in to do studs and found cylinder damaged, once it was tore down found wrist pin let go and a spun rod bearing. bought a DFC short block, put in delipped and coated pistons, stage 2 cam and valve terrain, studs, bd manifolds/ up pipes.
7.3powerstroke00
Brownwood
sent from the best place on earth! TEXAS!
RSK
Connecticut
well my trans finally gave up, at 124,000 clutches were shot in direct drive, so i didn't drive it for almost 2 months but i just drove it to rudys and back, and made a pass there, trans is shifting great again, im almost at 127k no issues, track bar and passenger side tie rod had to be replaced but i plow with the truck on 22's and with 35's so i'm sure that had a little to do with that stuff wearing out so soon.
smcox1
I think I'm close to breaking 40k with my 08. Only thing I've had to replace was the radiator and fan after it got in a fight with a cat, but the cat didn't win LOL
