StrokiNDieseL
Put together like so, "re used" block machined/balenced w/standard coated/delipped Pistons on stock rods.
-cometic gasket kit
-stage1 cam
-side action lifters
-heads treated/flattened (no porting)
-springs/retainers,pushrods
-6.0 mani's- Hd uppipes w/provision
-WG dump to atmo
-bullseye Hp/Lp balanced wheel replacement *> ( I'M SURE THIS MY REASON DUE TO STOCK HOUSING?)
-newer HPFP w/30% 8-hole nozzles
-injectors flowed by Mpd
-Rcd ported intake
-No Limit Cai
-Alradco IC
-FTI TC, PTP shift sol in stock trans
-Arp's inside/out.
So I wasn't present for dyno run so IDK how hot it got but 50-75% throttle & I'm quickly at 1300-1750ish. Rcd intake w/IC & NoLimit but I'm guessing my issue has lead me back to me earlier research that the stock charger housing his my heat issue & would benefit from a compound replacement? Coated Pistons in there but cooler the better is the goal.. Suggestions anyone could add would be appreciated, thanks. Jayson
-cometic gasket kit
-stage1 cam
-WG dump to atmo
-Rcd ported intake
-No Limit Cai
-Alradco IC
-Arp's inside/out.
