Time to upgrade turbo
Athens, IL
I've been reading about your turbos for a while. Do you happed to have any videos with the 66 on one ?
Yeah there are several on YouTube. Search Midwest diesel or our channel at 11primm87
Or the 62.5rrrrrrr
Yes. Pretty new but the 65.5 and 62.5 are awesome. The 62.5 is mostly popular for the 11-14 guys. If you already have a 2015 then the upgrade isn't as substantial. Most got straight to 65.5's from stock 2015 turbo.
So with the 66 streetmax R and the H&S dual fuelers. Would it be worth putting 60 HP injectors in with it. Or would that be to much on the stock trans ?
The 6670R turbo, Midwest dual fueler and 30% injectors will support over 700. We have done 800 on the dyno and track MPH shows 750+ with 100% over injectors, ported heads and built engine/trans. Your stock Trans will not last forever at that power, nor will your stock rods. But we do have options to fix that too.....!!
The 65.5 StreetMaxR is good for 650 maxed out mainly due to the smaller turbine which has less top end flow and a little smaller compressor than the 6670R.
Here's a little example of what our 64mm turbo and dual fueler look like towing from over in my build thread.
http://powerstrokearmy.com/forums/showthread.php?t=64127&page=30
Did a little towing recently with the truck just to have a little bit of fun.
I towed a 25 foot Wakesetter weighing about 11,000 pounds from St. George to Salt Lake. There's one particular hill about 20 minutes out of St. George that we generally use to test product on. The hill is a long, steep grade between 5 and 7 percent and is about 10 miles start to finish.
Below are a couple of pictures we snapped of the PID's from that pull. Speed varied from 70-80 mph like it had nothing back there.
I was really impressed with the EGT's pulling that hill. We waited until we were about a mile from the top to snap the first picture and almost to the top to snap the second picture so you can see that the max EGT temp throughout that entire pull was (1097 degrees).
Six_Sloww
Southeast MI
https://vimeo.com/145729099
Here's a video of a 6670r
Made 700 in the wrong gear, wrong tune (yeah I pretty much didn't know what the f I was doing) and it was heat soaked from giving people rides all day.. Good turbo if you like having a truck that you can let your girlfriend drive without smoking out the road when she needs to pass, could tow anything I need it to, and blow the tires off at pretty much any speed you want.. If that's the kinda thing you're into.
ChattyCathy
Such a great looking truck!
ChattyCathy
Love it! What tires are those?
Ahhh you will have those dry sunny days to rip around.
erabbit4192
Michigan, living in jacksonville NC
Love it. We're you ever able to get the proper tunes for it ? And throw it back on the dyno before you put her away.
Beautiful truck by the way
Athens, IL
Yeah. When I owned the truck I tuned it. That turbo has made 750+ on many dynos and ran 11.3 on fuel. It's made a ton more on spray though...
Athens, IL
As far as I know there really hasn't been any changes mad to the truck since he bought it from me.
Pretty cool making 750+ on fuel and running 10's on spray.....
Six_Sloww
Southeast MI
Wasn't a bad tune, just the wrong one on the minimax.. Accidentally clicked it up on a nitrous tune and over fueled it pretty hard. It never smokes like that on the proper tune.
