As an Amazon Associate we earn from qualifying purchases.
F25DY_Jake
Wilson, NC
Added a new sticker..
Sent from my XT907 using Tapatalk
Black AOD
Ohio
those resistor get hot as *** too.. make sure it doesnt come in contact with anything that will melt...
I tried installing switchbacks on my old headlights for the blinkers, I had that issue. One side, the resistor would get so dang hot I couldn't touch it and it heated up almost instantly, the other side stayed about normal temp. I couldn't ever figure it out. Plus after installing the resistors, it didn't even cure the hyper flash issue with the blinkers....we tried new resistors and everything. Never figured it out
I tried installing switchbacks on my old headlights for the blinkers, I had that issue. One side, the resistor would get so dang hot I couldn't touch it and it heated up almost instantly, the other side stayed about normal temp. I couldn't ever figure it out. Plus after installing the resistors, it din't even cure the hyper flash issue with the blinkers....we tried new resistors and everything. Never figured it out
did you have led's in all 4 corners and resistors on all led's?
Pockets
Villa Rica, Ga
Nice. Now all you need is a mini maxx..
This is very true....[emoji17]
What kind of polish did you use. Mine need some work as well. Looks like the po washed them with a wire brush l.
This time I used White Diamond. I've been using Mother's but WD is the bee's knees....
WILD_PHIL
East TX
Replaced my CPS. Truck was kind of running rough. It's worse now so I'll be adjusting it when I get home from work.
