smcox1
- Joined
- Sep 14, 2012
- Messages
- 1,661
- Reaction score
- 0
I'm sure you're out of warranty anyway according to cts LOL I don't know how these clowns are still in business.
Automotivetouchup.com they can get you the color matches paint in an aerosol can. That's what I'll be using to do it myself.
I have ordered some touch up paint from them. Haven't had a chance to try it out yet but them were real easy to deal with. I need to get a couple of spray cans for the old F150 to repaint the roof and bumper.
Has anyone done a writeup on taking the emblem apart? I am sure I could figure it out pretty easily, just like to read what others have done.
pull it off the grill and tailgate and drill out the plastic spot welds on the back with an appropriate sized drill bit. the emblems will fall apart at that point. sand the pieces individually and expect ally around the edges and corners with some 120 grip paper, adhesion promoter could help paint stick, paint with your color paint and clear but keep in mind that tolerances are tight and it does need to go back together. dry fit first and you can alter slightly with a razor blade if needed. not sure whether id recommend two heavy coats each of paint and clear, or a whole bunch of misted coats of paint then and a heavy coat of clear. that might be a better question for a body guy.
Light coats work best. I'll have to do my emblems. Seems super easy.
What color black did you use on your emblems FX?
It's just matte black..... no specific paint code. Use easy off oven cleaner to strip the chrome finish off the pieces. Makes prep work a lot easier.
I haven't done the front and rear emblems but the fender emblems will come apart without messing the clips up..... or at least the did on my '15. Paint I used was from Automotive Touch Up and it matches great. I've used them several times including the paint for my headlights and every can has been perfect. Sand a bit, use some of their adhesion promoter, few light coats of primer, few light coats of body color and then a couple coats of clear.
