CCV mod
nbh1226
You would have to run tunes otherwise you will have a light come on.
To add on. If your going to ****** CCV your going to want to ****** EGR. Both are recirculating dirty gases and oil back into the engine.
dawashi
Looking at doing this i just ******d and removed egr seen this in my intake pipe
is that really how bad it should look?^^^ i pull my intake hose off every time i check my filter and i see no where near that amount of oil in mine...
dsmracing1
Alberta, Canada
My unit looked like that after 10000 miles lol. It's pretty crazy how much gets in there in such a short amount of time!
dawashi
The truck only had 13k on it finally decided to ****** it. It's a 2015 I never new it was that bad .saving up to h money for the Ccv mod next
Tx6.7Joe
Wow my 2014 w/ 56k has about a 1/4 the amount of oil upon inspection during my ****** process 2 months ago. What's the mileage on your truck dawashi? and what would cause more oil to gather up in there than others
usually the harder you drive it the cleaner it stays.. mine had maybe a half of a thimble full in it....
dawashi
I haven't driven my truck hard at all I try to baby it as much as I can. It only has 13000 miles on it. Has anyone here or try to aftermarket crank case breather can?
nbh1226
Try this at about 160k. CCV is happening soon for me. That's not even the worst picture. That's at the air intake valve.
Tx6.7Joe
I've heard of people using a Mopar catch can. I believe off the old 12 valve Cummins
