U509E code. Ok to drive??
Mesa, AZ
I was afraid of that. Thanks for the clarification. It's looks like something I can put on though. Does a new module have to be programmed?
It does not have to be programmed like a pcm or anything, however there is a parameter reset that needs to be performed. You may be able to get away without doing the reset, but i have never tried.
Mesa, AZ
emissions should be 5 years and 60k miles. Goto diff dealer
The problem with that is that these are not considered light duty due to the gvwr. I went thru a fiasco with esp and normal warranty, as esp said it was covered by emissions till 60 or 80k, as thatwas what it was on a normal vehicle. Part number was coming up as not covered. Warranty admin pulled out coverage, and it was covered by emissions as.long as something like 8499 or less gvwr, over 8500 or whatever it was, may have been 8000, it was nly covered to x amount of miles
SpyderX
Boaz, Alabama
I didn't do it for the extra power either. I did it so i didn't have to post about the things you are going through lol. When I dleeted there was h&s or s p a r t a n. Im clueless now with all the possibilities. Id pm bigpowr on here and he can certainly straighten you out and get you what you want without breaking the bank
Sent from my SM-N920P using Tapatalk
I couldn't locate bigpowr on here. Could you help me connect with him?
SpyderX
Boaz, Alabama
There's another member on here that works there too....Jeremy @ no limit
Awesome. Can't wait to get this crap off my truck so it can eat. Everything seems pretty easy to install. I want to keep the factory tail pipe though. Is there exhaust that allows that?
Nj67
South NJ
Not sure
yes, just buy the deelete pipe not the full exhaust.
SpyderX
Boaz, Alabama
No start 2nd day after recall done. Now showing same U059E and P068A. The video below is what it does. Bad ecm/Pam relay?? Calling ford first thing this morning. Batteries checked at 12.7V
https://vimeo.com/155108757
Mesa, AZ
It needs batteries. Seen this quite a tew times. Check connections too though. Just because theyve got 12.7v doesnt mean they have enough juice to crank it.
SpyderX
Boaz, Alabama
Good lord. I bet batteries ant cheap in these trucks. Guess the new tires will have to wait.
SpyderX
Boaz, Alabama
It seems like the batteries should last longer than this. It's a 2012. Are diesel trucks harder on batteries?
of course they are. heck on our six oh's they are an annual replacement part.
SpyderX
Boaz, Alabama
I did notice it took longer for glow plug light to go out. I think u guys are right. Bad batteries. Well Ford is on the way to pick it up now, at least that's covered!
SpyderX
Boaz, Alabama
You were correct. One battery was showing 65 cranking amps. [emoji106][emoji106]
Mesa, AZ
Always replace in pairs! If you dont you will be putting the other one in in a few months, then this one again, etc.... The bad one causes way too much draw on the good one, which will test fine now, but eventuallywill chit itself in the near future and youll be in the same place you are now.
SpyderX
Boaz, Alabama
Well crap. Thank you for the info.
