7" vs 8" stack comparison
cap
Eastern Shore MD
First off let me preface this with the fact I'm not on here nearly as much as another forum...
I'm looking to switch to a single mitre cut stack. That being said, I have a hard time picturing how things will look without an actual picture. If you have a picture of your 7 or 8" mitre cut stack on a crew cab (preferably 6.0) could you please post it so I can get an idea of what I think I would like? Thanks!
Jake
Koda22
Ruidoso, NM
What's the truck look like? Lifted? Tire size? I think all that comes into play...but I'd say a 7inch is the perfect middle.....not to bug but big enough....
Mesa, AZ
I put a 6in on mine, i will say it was a lot bigger than i thought. I would go to an exhaust shop and look at angle cut tips, a they are more likely to have those in stock, in the size you are looking at. My 6in, i believe measures around 8in at the opening due to the fact that it travels down the pipe as well as across it, the pipe itself measures 6 across but the hole for the exit is huge.
cap
Eastern Shore MD
its a black 06 KR on 35s, it looks pretty stout. I have taken the running boards off since this picture...I wish I hadn't now but I just moved to Kansas and left them back in Maryland :fustrate:
7.3obs
Nice looking truck. What I think would look good on that is a set of black flopro? Idk what exactly they're called. They're the duals but are right next to each other. Made in Florida I believe. My friend has them on his black duramax. They're pretty nice and I feel would set your truck off nicely.
Lipka101
Maryland
If you do a single make it a 7". 8" just past that borderline of too big. I think you should buy this tho. [emoji12] uploadfromtaptalk1455249091619.jpg
Sent from my SM-N910V using Tapatalk
Koda22
Ruidoso, NM
Yea shotgun/side by side stacks are pretty nice...if you do that I really wouldn't go over a 7inch ......
And a heads up its made by SoFlo Diesel......
Radioflyer
So-flo. We're a dealer for them if anyone is interested. One of our guy's here is good friends with Adam at so-flo. Only stack i'd ever consider putting back in my truck.
slowcoupe
Las Vegas, NV
I have run 7" singles in of my my last trucks. Cab height on my crewcabs and a short on my RCSB truck.
7" is perfect in my opinion. 5-6" looks too small and a 8" is starting to be a little gaudy.
