BLOCK TO RUN 2 IPR'S
how much?
seems it would aid in purging air from the rails
God you would think it would eliminate a lot if air....i think thats the cause of all the chop in idle on a lot of these trucks.
Hotrodtractor
Mingo, Ohio
I have to go look... pretty sure I only have one left and its needed for a truck.
Its interesting to see how many people have made these since I posted the idea and then pictures of the first one online.
Chvyrkr
I was gonna ask if I should find one or not.
njjeep
Brick, NJ
Mine that i made. Had a few people ask for one just haven't had the time.
Wow that's looks really good! Can you explain how it works? I kind of have an idea. Maybe some more pictures would help too.
Thanks
ja_cain
I was messaged by a member on here that might have drawings for one that he made. He said that if he can't find the cad drawings he would be willing to send it to me. I'll get the dimensions and then have the lab manager draw it up in inventor. After that, I'll share them with anyone that once to make one.
Does anyone know the thread type of the ipr's? I'm thinking of just doing everything on the lathe in the 4 jaw chuck once I've true'd up a block on the mill.
ja_cain
That looks beautiful. What mill (cnc or manual) did you make it on? What grade of steel did you use? I would love to try and make one. Also, are those jic to not fittings? It's interesting how you started the thread about an 1/8" down 8n the hole. I'm not a machinest, but I do some machining at work. I have never tapped npt threads that way.
superpsd
Missouri
Those look like ORB threads. (O Ring Boss) very common on hydraulic systems.
ja_cain
Ahh, that makes sense about the unthreaded section then if they are orb. I mostly use hip, swagelok and npt stuff at work. I do have the special drill/reamer/tap set to do the dynisco stuff too. I've never machined anything for orb, but have been exposed to it.
superpsd
Missouri
There is a high possibility there are off the shelf hydraulic blocks that may work with slight modification. A company I worked for had hydraulic test benches and we use sun hydraulics blocks for dump valves, regulators, compensators and such. The dump valves were exactly like the IPR valve but had 120VAC coils.
ja_cain
That would definitely make things much easier. I'll have to do a little research armed with that info. Thanks!
ja_cain
Something like this?
superpsd
Missouri
Only problem is the IPR valve is different than the average selector style dump valves.
4.0l sahara
shelton,ct
The treads are all ORB and mine was done on a manual mill. It's a block of titanium not steel. Aluminum would be fine.
ja_cain
I see the gold/bronze tint now. The one time I turned some titanium, I thought it cut like butter. I felt it was much easier to work with than the 316 I have machine all the time. That piece looks beautiful. Btw, thanks for the info about the threads.
