Rubenk
KCMO
Traction stuffs. Need to really wash the truck, installed the front true trac yesterday and our testing methods involved a little mud!
ouo and slicks or just the slicks?
Fuel filters on the 6.4. Whoever designed the frame filter, needs shot!
SDS97_7.3
Finksburg, Maryland
no.. just forgot to say that i second that issue.. i have only changed one and hope its the last.. lol
Got ya, between the frame and driveshaft I can only get about 2 clicks on the ratchet. Unless I'm using a 2' extension. Hell the cap and filter don't even fit between the harness, frame, and brake line without moving the brake line and the harness. How the ***k is that a good idea?!
SDS97_7.3
Finksburg, Maryland
I remember those days...Gawd I hate that filter.
Fuel Bowl ****** and a lift pump could be in your future, just saying :poke:
And before I bought a new socket, only one I had that fit was for a 3/4" ratchet lol. I'd like to, but have other priorities first. I'll deal with it once a year
Skill_Kills
Princeton MN
Today I bled the cooling system on my 53 and hooked the intercooler piping back up after it blew off. BEST drive around the block ever!
What size are those? I need something like that for my rat rod and cant find anything that would fit
Rubenk
KCMO
18x11 with 325/45 Hoosier drag radials
6fourstroker
Almost finished installing an iPad mini 3 in my dash. Bought the slider mount from soundman then got busy with the Dremel. The paint shows how imperfect my Bondo skills are but for my first time guess it's not that bad. The radio I bought to put in behind it didn't work, come to find out its refurbished. I've got the wiring done for the idatalink maestro Rr (let's me retain steering wheel controls) just gotta get this other radio put in and I'm set.
Sent while I should probably be doing something else.
