shmoozer
- Joined
- Jul 31, 2012
- Messages
- 1,143
- Reaction score
- 0
Sounds like it's about time for a dual pump setup. If only there was a more reliable out there
You have a good stock pump you could send me? Maybe trade and compare?Well that sucks. I was really hoping to try one of these honey badger pumps on my race truck.
Are you going to swap back on your stocker and see if ICP goes back up?
Sent from my SM-N920P using Tapatalk
StockSwinky what are you running for a rear driveshaft setup
Found a hole in my intercooler too.
You talking about the carrier bearing?Did you move the center support up? I got 3 leafs in the back and it v's at the center support
Mine is dead flat.Yeah, looks like a big angle change I didn't know it it would be a issue being lowered.
Well i dropped number 1 injector on the way to rudys and I'm tired of it. I'm bowing out. Truck might make a few more passes but I'm done with it. It will slowly be returned to a s362 and stock injectors. Maybe even a stock charger.
Nope just going to stock. Maybe do a 362 and some 175s or something. Tired of killing my crew cab king ranch........ hint hint.HUH??? why so small? are you selling it?
I will. My current setup is going in something else. So if I can get a set of uppipes and maybe a stage 2.5 charger I'd be happy.You make sure to hit me up if you want a "stockish" setup. LOL... that is what I specialize in. You know I will hook you up and give you a smoking deal on whatever you need.
