7.3powerstroke00
Brownwood
The only HID's I've seen in a reflector bowl that don't glare are the factory ones in my aviator. But every other yaahoo that throws in this pnp HID garbage are always blinding the hell out of me.
It doesn't help with all the guys that have the LEAN.... and hids.... just makes me want a million candle power spot light to flip on right in there face!
6fourstroker
Hopefully have these in Friday so I can get them in!!!
Sent while I should probably be doing something else.
mikeeg02
Drifting, PA
^^ those head lights look pretty sweet.
Rear brakes, rotors, calipers, inner axle seals, changed diff fluid. It's amazing a Dana 80 takes more oil to fill than most car engines haha!
Rubenk
KCMO
How much does it take? I'll be doing mine soon.
6fourstroker
Thanks! Should look great on the truck. Veeeeeery pricey tho
mikeeg02
Drifting, PA
Book says 5.5 quarts. I just put all 6. Also I believe all the SRW trucks have sterling rear axles. They don't use quite as much oil if I remember correctly.
6fourstroker
How much does it take like work wise, or money? Lol I didn't build them, but they did cost a pretty penny. Could have been done for $700-800 conservatively. But I went with some added cool stuff ha
Rubenk
KCMO
Sorry, meant fluid capacity. I had one built and is getting shipped to me dry, so I need to fill it up. I wish I only spent $800 on it! :)
I had the same set up in my 6.0, my 6.0 was higher, I never had any issues with oncoming traffic, I even did my own drive by with my wife, I was in her car she was in my truck and it wasn't an issue. People with high beams were way worse even while I wad in my truck.
welcome to PSA man!! good lookin truck..
6fourstroker
Ordered vanity plates [emoji48] and hopefully will receive my retrofit heads so I can put those bad boys in
Rubenk
KCMO
Went to the track, set a new PB and my truck is officially an 11 second truck! wooo...full post to come.
Mesa, AZ
Put in a new csf intercooler and no limit hot and cold sides. Then went and ordered 2 heads, as i found fuel in the coolant when pulling my airbox out :fustrate::cursing:
