1999-2004 Front Hanger kits.
greyford1979
Copley,Ohio
I have 2 sets of Front hanger and shackle kits I'm getting rid of for 99-04 Super Dutys and Excursions. The first set was on the truck when I bought it. Not sure of the exact size since it sat a tad higher than it does with the new kit, I'm guessing maybe 2.5" or 3". Only thing with it is the small notched out area on the driver's side hanger where it looks like the previous owner must have notched it to replace the front rad support bushing. Not sure of brand either, but they are stout hangers. The second set are the PMF 2" inch kit, only been on the truck for 2 weeks. Nothing wrong with these, just a small nick I put in the driver's side one during install, well and of course probably on the inside where the spring rubbed during install. Just decide to go a different way. They will be on the truck till I get a new kit installed, won't take payment till they are taken off, hopefully next weekend. If local within a reasonable distance I'll deliver them to you no cost. I can post pics of how the truck sits with either kit upon request. Thanks for looking.
Asking $50 plus shipping on the first set.
Asking $225 plus shipping on the PMF set, Cost $299 plus shipping new.
sqrlgtr
Post a pick of truck with 50$ kit plzzz.and do you think a feller would have to use adj.Trac bar with these??
Thanks
sqrlgtr
sqrlgtr
Never mind I believe my early 99 takes a different kit,sorry
sqrlgtr
greyford1979
Copley,Ohio
Thanks
sqrlgtr
First pic is with 285/75R16 Coopers, just over 33" and second is with 295/70R18 Coopers, right around 34.5". And to be honest, I'm not sure if you would need an adjustable one or not. My truck had some kind of weird adjustable setup on it when Bought the truck and just threw an adjustable one on in the stock location when it needed replaced. I know there are guys that run them with stock ones, but not sure
Could this be added to a mini spring pack to reach abut 4-5 inches of lift??
Honestly I'm not sure, I don't wanna tell you yes and have it end up being unsafe or bad on the suspension. Maybe some suspension gurus will chime in.
Im not a guru but I dont see why not. Going random sizes of lift you may find issues getting a tracbar the right length but you may also be able to just fine.
Then im not sure on pitman arm if you'd need a 4" drop or what.
sqrlgtr
I was under the impression that a early 99 took different shackle and hangers but have been researching interweb and belive they are the same.does anyone know for sure if the early 99 is the same as the later 99.5-2003 trucks?
Thanks
sqrlgtr
greyford1979
Copley,Ohio
I'm not sure exactly if they are or not. All I know is that when you order aftermarket hangers, it just says 99-04. You could call your local dealer and have them see if the part numbers for yours are the same as the later years.
greyford1979
Copley,Ohio
The PMF kit is off the truck, was on for only 3 weeks. This will be shipped in original boxes if someone buys them.
Dmstrucks02
Pearland, TX
I would have already bought these if they were 3", I just don't think 2" will be enough for what I want
greyford1979
Copley,Ohio
No problem man, that's actually what I ended up swapping out to was PMF's 3 inch kit because of the weight of my bumper LOL.
