Best fog light bracket? Rigid or KD fabworks?
Clean-15
Anyone used both or have an opinion on fit quality? It seems like some of them don't center the light perfectly. Maybe that's an install issue. Also does one stick the light out further than the other? Thanks in advance!
Administrator
i used the diesel cartel kit with rigid duallys . worked perfect .
Is there a kit to put these in xl trucks or do you have to put stockers in first?
Josh@DirtyDiesels
PA
You need the stock fog light brackets. While you're at it you are best off just buying the oem kit for ~$200 depending on where you buy. It comes with brackets, lights, shrouds, harness, and the switch with fog option. Then you can just use the plug and play harnesses when you add rigids and operate them off the factory switch.
That's what I figured but couldn't confirm. Thanks
Lugger007
Ct
Do you happen to know the ford part number for this? I'd like to order the ford kit so I can the. eventually order the led fogs
