Fuel pump location?
cjfarm111
Just got my new fuel lab pump and filter setup from irate diesel and I can't decide on where to mount it? Anybody have this setup or have an opinion on where the best/safest location is?
Powerstroker7.3
waxhaw NC
Mine is on the drivers side frame rail. It is in between the front door and back door of my crew cab truck
joe d
monroe mi
I made my kits not that different tho. I just mounted them as hi and as close to the t case as possible. The only way to hit them is to get into a situation were the last thing your worried about are them pumps lmao.
Dmstrucks02
Pearland, TX
I don't have Irates kit, but I mounted it just in front of the tank and right behind the traction bar mount. That's the only spot it would fit inside the frame rail.
KBMKVIII
I did a twin super duty pump set up in parallel.
Located outside of the frame rail under the bed.
My filters are much larger than the kits use.
Tucked up as far as I could get it.
I also made a rock guard, not pictured.
Tapatalking from a wind turbine
