zilla68
I'm pretty sure that some of you guys on here are using them. I did a search for xrf and nothing came up.
quality?
I'm going to replace the entire front tie rod set up, this set from orielly's didn't last me but 7 years, but probably doesn't have more than 8k on them.
Issue is I'm getting a bad noise when you turn the wheel back and forth. I just did axle seals and thought it was maybe a wheel bearing, but all was good, noise is still there. It sounds like its coming from passenger side, but then again it sounds like the drivers side laying underneath it. really hard to pinpoint this.
I don't see excessive play in anything up front, like I did on my jeep when I had issues, they were pretty much in plain sight.
I'm going to pull the old tie rods off and see if there's any play in them I'm not seing by someone turning the steering wheel while I lay underneath it.
just want to get some part numbers ready to order if anyone has used the xrf set up with good success.
quality?
