F450 rims
WHY NOT
Carlyle IL
19.5's will ride rougher due to the higher ply tires. Pretty sure American force makes a direct bolt on 19.5. Eagle Alloy also makes 20's for DRW trucks that look good, you will have more tire choices and will probably be cheaper.
psduser1
on the road
19.5 American forces.
Yes they ride rougher than the light truck tires.
About 3k in rims, 3k in tires, plus mount and balance, at 100$/tire, per rickson. I can't recommend them if you are picky about the ride.
tbsimmons
Bakersfield, CA
They do ride much rougher. I don't miss my 450 ride at all. Even with tires down to about 50-60 PSI it still rode rough. Unless weight reasons I would not go with half sized wheels and tires again.
IHPowerstroke7.3
Toronto, Ontario
2014 right, couldn't remember what year they switched. Wouldn't a 2016 350 be a 17" as well? You wouldn't be able to put the f450 rims on the 350, 10 bolt pattern. Would have to go with an aftermarket rim. I agree with what was said, unless you need the weight rating of the 19.5" tires don't do it.
Zmann
2011-2014 they might be 17 but i don't think they look cool like the "real" F450 rims the OP is seeking
they are just F350 rims aren't they
Zmann
we were posting at the same time you just snuck in under the wire LOL
psduser1
on the road
Couple more.
