2005 slow crank no start... Ideas? Help appreciate!
2000BigDirty7.3
So here's the sorry I bought a 2005 f250 crew cab sbox from a service center up in hornepayne Ontario, bout 12 hours from me I got it for 2200 bucks dirt cheap rot free body and 4700 dollars worth of work done to the front end and rest of the truck. Buddy repoed the truck from the guy who didnt pay, unfortunately it was in the middle of doing new injectors and I got it with the engine in pieces, finally got around to putting it back together and I get a slow crank and no start with both my 7.3 canada proof batteries in it.... Can anyone help... The link for video is below
https://www.dropbox.com/s/smlyphot0qe07zl/VIDEO0162.mp4?dl=0
Sent from my HTC One M9 using Tapatalk
DEEZUZ
NO PUKESTERS
NWI
take the belt off, see if the AC compressor is locked up.
DEEZUZ
NO PUKESTERS
NWI
actually that thing sounds toasted. sounds like very low compression.... hows blowby while cranking?
DEEZUZ
NO PUKESTERS
NWI
not a fan of the cranking cadence.... it just sounds dead... does the engine have any kickback? like if cranking and you stop does the belt kickback? I have also heard this with a plugged exhaust holding valves open or a seized turbo not allowing air in
Oroville, CA
Sounds angry. I'd swap on a known good start just to be safe but I think you're in for a junk motor.
ascrap2003
Check cranking rpm I think you need at least 160 rpm bare minimum to start anything under that I would replace starter than have a good charge and check compression before I put any money into that truck
