700 hp goal build
joe d
monroe mi
Man thats moveing... For a big truck. I wonder how slow 238-100 and a s366 is lmao. How street friendly are yalls setups.
Track time in my sig..
Thats faster than my time on 35s and with a 38r. I need trac bars though. Now my lift is off, rearend is fixed and tracbars are on thecway. Hoping for a 13. Ccsb 00 7.3 hbsr irate fuel pis 250/200 billet 38r...built billet trans..
FL
You should be about there with that set up, getting it lowered should help a ton. I was gonna run my truck tomorrow, but ended up having to work. I still have my stealth stage 2 sitting on the shelf and I'm on 37s now. I was hoping to break into the 12s.
powerjoke73
Is stock drivetrain gona hold up? I have traction bars but can the driveshafts hold the power?
Powerstroker7.3
waxhaw NC
I have been running stock drivetrain so far and no problems. I have track bars but that's it. I'm sure you have gauges and this is where the boost gauge is used. To know what psi to launch at. I usually launch between 10-15psi of boost but with some practice you will find the sweet spot
powerjoke73
Yeah I knew the sweet spot on my old setup (did some 4x4 boosted launches on back roads). Would leave around 12 psi. Just have to figure out the new setup and then see if I need anything adjusted
Tick-tock....
