evidently these trucks are prone to early failure of the steering components. i have 82k miles on mine and it appears that every joint in the front is getting sloppy except the 4 axle ball joints. the
2 tie rod ends, drag link(2 ends), and trac bar jojnt all move..
so if you guys could, post up what route you took to fix everything and how well it's held up so far and where you got the parts.. cost if you want also.
normally i would go straight back with oem but it also seems that once replaced, they wear out quicker..
so factory, aftermarket cheap, or aftermarket expensive? what say you?
