you know yeah let me get that vin, unless you know if you have the fatboy axle?
when i typed it into fordparts.com the fatboy didnt show up. but did when i just did a regular model search so i would say no it doesn't. but here is the vin ayway..
can you add part #3281 to the quote also?
sunrisefordparts
heres your quote .
  • q444514.pdf
ok that worked. i forgot how to do this. lol.. do i just call the parts department and give them the invoice number and then payment info?
sunrisefordparts
that or give me your email and ill send the paypal link right over.
little luke
Union County, Kentucky
Need price on upper and lower ball joints, tie rods, and adjustment sleeves for a 2002 ford excursion, 4x4, 6.8 shipped to 42404.
I'm rebuilding the front suspension so if I missing anything include that as well. Thank you.
sunrisefordparts
that's a pretty good rebuild, other then the hub bearings and associated seals for them your looking at a solid front end.
  • q444888.pdf
sunrisefordparts
Looking for price for rear leaf springs for a 2011 F-250 without overloads.
Wanting to swap them into my 2002.
the springs are quite expensive, list $595.98 each sell $429.11 each. I know they are wider then the 2010 and down so you will need hangers and shackles for the swap.
kdsf350
Oregon
08 F350 6.4 Diesel Lariat Crew Cab
Price quote please: Cab body mounts for all positions and bolts. Thanks
Lugger007
Ct
Ac condenser
Tail gate top black molding
2012 f250
Thank you
Lugger007
Ct
condenser list $317.71 sell $247.81
moulding list $82.10 sell $59.11 ( I assume without step)
q#447816
shipping $15
Does that condenser come with the ac accumulator assembly (bl3z-19c836-b) and the left/right seal kits (9w7z-19b596-a)? If not, could you please update the quote to include it and remove the mounding from the quote. I'll order the moulding another time.
Please provide PayPal email for payment.
Hopefully these are all stock parts. Thank you
sunrisefordparts
the condenser will have the accumulator, and the seal would be separate at $12.72 each. the total on the ticket for the condenser and the seals is $273.25 and our paypal is payfont@sunriseford.com.
duddy
sloshkosh wi
8ra47463
2 rear seals.
8 rod bearings
1 main bearing set
16 injectors feed line kits
Gaskets for putting together one 6.4
Putting two engines together. I will call and talk to you after you get a initial quote.
