Extremely high base oil psi
DEEZUZ
NO PUKESTERS
NWI
Cold the pressure reads about 112 psi @ WOT. Once warm psi is 82 WOT. Inspected pressure regulator. It was fine but I did go ahead and try a new one. No change. It Blew out a new oil pressure sending unit so there definitely is a concern with this pressure I'm seeing.
DEEZUZ
NO PUKESTERS
NWI
15w40. Highly doubt it. I've installed hundreds. The regulator should bleed off anything over 75
DEEZUZ
NO PUKESTERS
NWI
One thing I can't find in all my information is where exactly that excess oil is bled off to. And I don't have a front cover off at the moment to verify it.
DEEZUZ
NO PUKESTERS
NWI
I would expect and have seen 100, but when it's single digit Temps. Not summer time, and not 82 psi when oil is thin @ op temp
webb06
Seneca, MO
What is the main concern the truck was brought in? Oil leaks? Or leaking from the sending unit?
DEEZUZ
NO PUKESTERS
NWI
the relief is set to 75 psi. anything over then it over comes the spring pressure and bleeds off.. issue is i cant find out where it bleeds off to, to check for obstruction.
the complaint was it was leaking oil. I found the NEW sending unit blown out. Then I verfied with 2 mechanical gauges what pressure was. IMO its very high and will blow out the sender again or turbo seal perhaps
webb06
Seneca, MO
Looks like excess pressure is returned to inlet side of pump.
DEEZUZ
NO PUKESTERS
NWI
I bet it's relived through the tiny port in the oil pump cover. I might pop that off
DEEZUZ
NO PUKESTERS
NWI
66 psi cold idle and 96 wot cold under load.
Hmm... Might ship it.
DEEZUZ
NO PUKESTERS
NWI
101 psi in neutral wot with oil @ 100°.
Thinking about tossing a flush in the oil as well.
DEEZUZ
NO PUKESTERS
NWI
Sorry. Tossed in New sender and shipped it. Next day cold wot full load was 96psi
DEEZUZ
NO PUKESTERS
NWI
Also tore off a oil pump on another motor and verified the bleed off port. Still puzzling why this truck sees anything more than 75
