Complete 15,000 Mile 7.3 longblock
Status
Not open for further replies.
PowerstrokeJunkie
Maryland
I have a engine i bought for a spare in case i had an issue with my truck in the future, however since im not pushing my truck much further than what it's at now, i am deciding to sell it. The engine was in a international truck, t444e version of the 7.3. Everything inside is the same, however the engine mounts are different, the exhaust manifold and oil cooler on the left are different, and a few small other miscellaneous things that are interchangable.
The great thing about this engine is that it is as fresh as you'll find for a forged rod 7.3. It has 15,000 miles since being a new reman, and i did a compression test on it when i got it, the pressures from all 8 cylinders ranged from 420-440 psi static compression.. (!)
I would like to sell this to someone who needs a good forged rod engine, however i dont need to sell it. I'd like to see $2000 for the engine complete minus HPOP, turbo, injectors and water pump. If youre interested im sure we can work something out.
CSIPSD
Bend, OR
Sounds like a good deal... Wish I had the cash or I would grab it.
PowerstrokeJunkie
Maryland
As far as i know, no. It has the different IH pan and pickup on it, however visually from the outside it looks the same, im confident its the same front cover.
PowerstrokeJunkie
Maryland
All you would have to do is run it a little while and you'd bend the rods to where you would want your compression to be :doh:
kyle43335
In the Brig (Banned)
headgaskets in those engines are thinner than 7.3/ford gaskets. dont take that 444 over 3500!!!
PowerstrokeJunkie
Maryland
Did ford remove every headgasket on every 7.3 navistar sold them and put a thicker gasket on it so they could feel comfortable revving over 3500?
kyle43335
all i was mainly referring to,was that the hg thickness is thinner on these engines. the engine manufactured for the international chassis never seen fords hands in anyway shape or form. try not being a uneducated ***tard,to only save your worthless sale thread.
STROKIN N STYLE
GOM via NC
What is wrong with people in this forum. You sir are a piece of shiz for even making a comment like that. This forum needs to be weeded of the dicks!
Status
