Oasis/carfax 2008 6.4 - blown head
fubolislif22
Hey guys,
Can anyone please help me out and possibly get me an oasis/Carfax report for a 08' 6.4 with 150k miles I'm looking to purchase within the next week.
Just some info on the truck as it is now, guy purchased it with a blown head-gasket and got the truck bullet-proofed by a reputable shop that has done plenty of 6.4's:
Truck has new OEM ford heads, gaskets, new rockers, push-rods were checked, new oil-cooler, ARP head-studs, up-pipes, turbos have been rebuilt, moshimoto radiator, trans is built, no emission restrictive equipment it has been ******d, SCT tuner, straight piped, cold air-intake. All fluids flushed and replaced
Not sure if the blown head gasket would show up on the report but I'm inclined to think that this motor should be pretty reliable going forward, don't you think?
VIN IS 1FTSW21R68EB12297
Thanks in advance guys!
fordpulling29
northeast PA
Detailed Vehicle Specification
VIN 1FTSW21R68EB12297
Vehicle Line T/F7 Market Derived Code F
Body Cab T/BC Ver. Series T/BD
Drive Type T/E
PLT CD A1 TRS CD T/BE ENG CD T/QL
Production Date 11-MAY-07 Warranty Start Date 04-JUN-07
Selling Dealer 123548 Selling Country USA
AWS Claim Key Trx Code Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc
Details 4283390 08B06 28 .3 TERREBONNE FORD LINCOLN 45995 27-AUG-09 * * * 363370B
Customer Comments RECALL 08B06
Tech Comments 45995 INSTALLED VENTURI TEE KIT AS PER FSA 08B06 08B06B 0.3HR
Details 4283393 08C04 28 .9 TERREBONNE FORD LINCOLN 45995 27-AUG-09 * * * 363370E
Customer Comments RECALL 08C04
Tech Comments 45999 INSTALLED FUEL TANK STOPPER BRACKET AS PER FSA 08C04 08C04B 0.9HR
Details 4283392 08C01 28 .3 TERREBONNE FORD LINCOLN 45995 27-AUG-09 * * * 363370D
Customer Comments RECALL 08C01
Tech Comments 45999 SEAT FRAME U BOLT RECALL PERFORMED RECALL ON LT FRT SEAT BRAME U BOLT 08C01
Details 4283391 08B07 28 .5 TERREBONNE FORD LINCOLN 45995 27-AUG-09 * * * 363370C
Customer Comments RECALL 08B07
Tech Comments 45999 REFLASHED PCM AS PER FSA 08B07 08B07B 0.5HR
Details 4283389 E95 28 1.4 TERREBONNE FORD LINCOLN 45995 27-AUG-09 1L3Z 4676 A 363370A
Customer Comments DIAG REAR END OIL LEAK
Tech Comments 45999 INSPECTED AND VERIFIED CONCERN. REMOVED AND REPLACED REAR AXLE PINION SEAL AND TOPPED OFF FLUID. CLEANED EFFECTED AREA AND ROADTESTED TO VERIFY REPAIR
fubolislif22
Thank you for that, looks like the truck was in one time to get all of the above things done at once, nothing major either. From what I can tell it looks pretty clean?
fubolislif22
no telling this only tells me what was done under warranty but it dosn't look like it was a problem child
Yea for sure, assuming the warranty ran to 100k it looks like it had minor issues labeling it a "lemon". Other then the fact that he bought it with a blown head and went the extra mile to fix it and bulletproof it. Makes me feel better about what I'm getting myself into. I've seen other reports with numerous issues being fixed under warranty that can be labeled as a "problem child".
fubolislif22
Anyone have any other input on this, such as product date ect? I plan on buying my next truck and driving it into the ground... :pimp:
then dont buy a six four...it will run you into the ground before you have a chance to run it into the ground
fubolislif22
I have read the reasons why they fail, but in my description above does the work done to the truck not a-quit for most of the issues that cause the truck to fail in the first place (its not a stock motor it has had work done to it and ******d)? 6.7's are to expensive I want a paid off truck and the 6.0's interior are out dated for numerous reasons.
no telling when one will eat a lifter, crap out a hpfp or crack a piston. horribly unreliable if you ask me.
besides, older six sevens are coming down in price and are way more reliable. i have a 2012 in the classifieds i am willing to take offers on.
fubolislif22
I hear ya on that, but are those issues more common then the majority of the reported failures (in this case the head, which is now new)? I'm not a pro on diesels besides the research I have found over the last couple months. The work done to this truck would make it seem like it had new life in it if maintained properly. The normal issues have been addressed and upgraded (is what I'm trying to say)
suprdzlduty
Prospect, Oh
Yes, it sounds like the current owner has addressed and tried to prevent future issues...the problem with 6.4's is the bottom end of the motor...of you drive it in a "stock" or close to it tune, and with some common sense, problems should be minimal...but as sootie said, when something goes it gets expensive real quick. Unfortunately more often than not the engine isn't rebuild-able and you have to find something that is or start with a new block. They only made them 3 years so the numbers aren't there to keep costs down...6.4's aren't known for their "years of trouble free service" for us that have owned them or worked on them
powerstrokelyfe
Op. as these guys have stated, your best bet is to stay away from a 6.4... lots of issues can arise, and it's very expensive to fix.
Looking at an older 6.0 or a 6.7 is you best bet.
fubolislif22
Even on a truck that has a brand new bottom end (short block), top end checked with new rockers, push rods, new hpfp, oil cooler, magnafluxed heads (basically emission free since it was started). This would still be something to stay away from?
sure it may buy you some time but wont prevent the inevitable...
powerstrokelyfe
Unfortunately, anything could happen. Cracked pistons and a host of other things can still go wrong..
fubolislif22
Can anyone run an oasis for me by tonight, I plan on purchasing a truck tmrw morning. Please PM me it will be greatly appreciated!!!
VIN: 1FTSW21R48EB46190
